auto trans switch/sensor black wire
btectonic
Post by btectonic »
Gang, I've got a leaky gizmo on the driver's side of the auto trans section above the pan (in the same general area as the manual reverse light switch). Single black wire goes to it, doesn't have a nut on the body of it like a typical sensor would.
Neutral safety switch? I'll post a pic later today to help identify.
The mechanic seems to think he needs to drop the pan and remove it from inside the trans case.
thnx,
Brad
Re: auto trans switch/sensor black wire
Oh...that is for the kickdown solenoid most likely. It has a rubber grommet on it. Yes, you might need to take the pan off and remove the solenoid to put a new grommet around the wire. Other items that it could be are the deceleration valve. I'll have to look in the book. Ray
btectonic
Post by btectonic »
Mechanic described the location poorly, it looks like it drops down into the valve body. Guessing it has a seal/o-ring at the valve body.
That is the kick-down solenoid...passing gear. Very important. I believe it had a grommet. I'll will have to pull out my parts book. The part number for the electrical connector piece/plug that is fitted into the tranny body is 003-927-113. The seal...which appears to be a grommet....is 003-927-115.
It appears that there is a bulkhead fitting (003-927-113) similar to a T-1 connector in concept.... that the female terminal for the solenodi unit plugs into inside of the transmission. In turn the female terminal for the wire to the transmission lugs into the outside. So the fitting in the tranny is a double ended male T-1 plug with a grommet around it. Ray
btectonic
Post by btectonic »
Thanks Ray, most helpful!
