Anyone have any Fresh air tubes?
vwbill
Post by vwbill »
Hello, I trashed my right side black plastic fresh air tube that goes from the alternator tin to the fan schroud! I would buy a set too! Thx, Bill,jr. I have a 74 VW 412 2dr 1.7djet
Lahti411
Re: Anyone have any Fresh air tubes?
Post by Lahti411 »
I've replaced all of my car fresh air tubes with aluminium ones as I couldn't find correct size plastic tubes. Aluminium tubes are available at any car part store atleast here in Finland. I just painted them black so they would have the original look.
vwbill
Post by vwbill »
I'll have to check! Thanks for the idea! The tube I'm looking for has 2.5" round end but the other end is oval and I don't know if I can find that type of end? It goes on that tin piece that goes from the right heat exchanger up through the engine tin and is next to the alternator... Thx, Bill,jr.
Lahti411
Post by Lahti411 »
Atleast a 411 wagon has a separate plastic "adapter" that fits on to the tube that's coming from the heat exchanger. This adapter has an oval opening for the heat exchanger pipe and a round opening for the fresh air tube in the engine compartment. But if you don't have that plasitc adapter part you can also easily mold the aluminium tubing by hand as it has wery thin wall thicknes.
The adapter i'm talking about is the part number 23 in this picture:
wildthings
Post by wildthings »
There were several different style of these boots/adapters. The exact one used depended on body style. BTW they don't connect to either alternator tin or the fan shroud.
vwbill
Post by vwbill »
No, this is the part of the heater system that connects the warm air duct(tin piece that is attached on top of the heat exchanger) from the heat riser on the right exhaust manifold that goes through the tin next to the alternator and connect to the heater blower fan on the plastic air intake fan shround that connects to the motor cast fan schroud. Thx. Bill,jr.
vwbill
Post by vwbill »
Here is a link to two pics. The first pic shows number 19 warm air duct on the right side heat exchanger that sits vertical on the manifold and come through the engine tin next to the alternator and the black plastic tube attaches to that oval end and goes to the heater blower fan mounted to the schroud that the engine lid seals to. See pic two and the engine bay heating system. You can't see the right side but it is like the left side but the one end is oval on one side and round on the other.
http://cid-a90d757ea7f74e80.skydrive.li ... r%20system
Lahti411
Post by Lahti411 »
This picture shows the differences in fresh air tubing between sedan (upper) and wagon (lower):
It seems that sedans dindn't have any plastic adapters between the fresh air tubes and the pipes coming from the heat exchangers. The fresh air tube is just clamped to the pipe.
And here you can see the connecting tubes (parts 53 and 54) from heat exchangers, through cooling tin, to the fresh air tubes:
vwbill
Post by vwbill »
The tube I'm lookin for is the one labled 28 and goes to the part 54 in the next pic. 54 comes through the right engine tin and the oval end of the black plastic tube attaches there and goes to the fan on the right side... Great images! Thx! I couldn't upload my images because my pics were too big file wise... Thx Bill,jr.
412s2
Post by 412s2 »
Type 4 engined Type 2s have a similar arrangement, I found these hoses at Just Kampers:
http://www.justkampers.com/shop/type_2_ ... 10316.html
I don't know what length they are, but they appear to be oval at one end.
albert
Post by albert »
BILL,, you can look in the porsche 914 parts distributor,, they got the same hose ,,or you can make one with a 90 deg. plumbery black plastic pipe 2'' 1/2 ,,pvc,,and heat that for to doo ,,ovale,,on one side ,albert
vwbill
Post by vwbill »
Thanks guys for all the info!!! I'll have to try out both ideas and still look for the originals too! Thx, Bill,jr.
p.s. Hey check this out it actually says type 4.. http://www.busdepot.com/details.jsp?par ... =211261236
wildthings
On my 411 2dr sedan hose #28 hooks to adapter #23 which attaches to duct #54.
albert
Post by albert »
BILL,, the hose in the bus dépot,, is for inside,, they are made with very thin alluminium paper and they are not made for many ,,manipulation,, if you have need a long section you can use the ,,shopvack,, hose,, albert
vwbill
Post by vwbill »
Wow, I'll have to look again and see if I don't have some kinda adapter there??? Great Idea Albert!! I was hoping maybe the Busdepot one might slide inside the original and I could keep some of the original look! Thx, Bill,jr.
