VW microfiches for Type 2 1968 - 1979
- david58
wildthings
Re: VW microfiches for Type 2 1968 - 1979
Think I will down load them and print them out. Do you think there is a higher resolution copy available somewhere?
- david58
Not that I know of these are the best ones I have found. Instead of printing them you could save them as a pdf file, then you could print out the pages you want when you want. I found this free printer add on that automatically make a document into a pdf file.wildthings wrote:Think I will down load them and print them out. Do you think there is a higher resolution copy available somewhere?
http://www.cutepdf.com/download/CuteWriter.exe
You may have to D/L this too.
http://www.cutepdf.com/download/converter.exe
Now once you do this you can save almost anything you have on your screen as a pdf file. If you want to save a web page click on file then print and select the cute pdf writer. This works with anything that has the print option MS Word Note Pad and so on. If I was going to save all the pics at that site I would copy and paste the images into MS Word, because it has a option to change the brightness and the contrast. Neat thing about pdf files is they are small when compared to pics saved in other formats. If you put a bunch of pics in pdf then you can e-mail them all at once and the file is small. I think it is a great tool to use. Look at the pics that aren't on the STF granted we haven't lost boo koo of them, but if they were in pdf the file that was uploaded then it would be saved by several members.
