1.9 and 2.1 case differences?
- Mr. Electric Wizard
I have a 1.9 block that I am wanting to use a a base for a large displacement Oxyboxer.
I am under the impression that the only real difference between a 1.9 case and a 2.1 case is the flywheel bearing size. The 1.9 using a Type 4 bearing and the 2.1 using a .040 Bug bearing.
Are there any other differences.
A 1.9 is what I have now, and I really would like to use it since I already have it.
But I do have a stock 2.1 in my '88 Vanagon (that recently got rebuilt before I bought it), but it might be a while before it craps out.
I'm sure DPR can make me a frankenstein crank that will work.
Is there anything else I am missing?
- Unkl Ian
Re: 1.9 and 2.1 case differences?
I think the 1.9 is first choice, it uses all T4 mains.
- Unkl Ian
Don't know why VW used completely different bearings for the 2.1 motor.
Making it a stronger bottom end.
Ok, so what I'm building:
1.9 case
84mm CW Crank
Type 1 rods
101.6 P/C
Turbo, MS fuel and spark.
1.9 case
84mm CW Crank
Type 1 rods
101.6 P/C
Based on the stroke I'm wanting I think a 2.1 will work much better.
At least it will make it possible.
The top of the case would be getting super thin with that large of a crank in there I suppose.
- Unkl Ian
I've read the top of the case has more room than a T1, so it will handle a large stroke.
- Unkl Ian
I've seen some 2.1 cases in the classifieds on Samba.
- fastback
U get the 1,9 in both early style bearings and late style bearings.
the early does not have the "B" in the partnumber on the sump.
025 *** *** B
025 *** *** B
- Unkl Ian
Late 1.9 bearings are the same as 2.1 ?
- fusername
I thought 1.9 used all BUG bearings, not T4 bearings, except for a special flywheel bearing... I have tons of 1.9 mains with no use for them, if they fit t4 i would use em, but I thought that was incorrect.
- Unkl Ian
Mr. Electric Wizard wrote: 1.9 case
84mm CW Crank
Type 1 rods
101.6 P/C
Air or water cooled ?
- fastback
i have heard that using vw journals and 84mm stroke u can run into clearance problem in the case.
but this was not pauter rod's which are beefier in the big end than stock rods
Jim Andritsakos
The early 1.9 cases (up to 12/85) uses bug style bearings and one piece thrust bearing they also does not have the front valve drilled.
Later from 1/86-on use chevy style bearings with 3-piece thrust bearing 1.9 & 2.1 same cases.You can use a 80mm crank w/o any clearance required in a wbx case.The very very late cases has a diagonal support rib in the alternator mounting plate area.
nikos
Hey Jim,Jim Andritsakos wrote:The early 1.9 cases (up to 12/85) uses bug style bearings and one piece thrust bearing they also does not have the front valve drilled.
I'm starting a oxy build here in Crete and might need some parts. Pm if you want to chat/help out w/ sourcing some parts...
thanx,
nick
