my 412
Lahti411
Re: my 412
Beautiful car! Which seats have you installed to your car? Is the rear seat still foldable? I love the original type 4 front seats (they are even better than my Saab 99's) but wagon model's rear seat is too flat. I'd even say it's pretty uncomfortable...
albert
Re: my 412
hi,,lahti,, for the front seat,, first i got 2 car ,,,one audi 200 -1990 plus my 412,, i have take the same model of audi seat ( 100-200-1986 TO 91) the dimention of the audi frame and pading are appx. the same with the 412 ,, i buy in the yard one set of audi seat for my 412 ,,for my first test i have transfert the 412 latherrette on the audi padding,( appx same dimention ) ,( they are full élect...heating too )) and afther a year i have find in my yard ( i paid the seat 25.$ each in my yard ) a nice set of ,,,merc,190,,year 90,,,, and i reemoove the 190 lather on her foam,for to put on my audi frame ,,and for the rear i have use the merc.190 foam padding and lather , for to put on my 412 frame,,we are lucky the 190 is more lardge,,plus the lather on the 190 is betther quality ,,the audi seat are very comfortable,, the bridge on the pict is at 1k,mils of my home ,, i have put 4k,mils in 15 days on my 412,,no méc. problem,, plus i have keep the hiway légal speed ,, 70-75 mils,hrs,, for a couple ride of 200 miles non stop,, it was fabulous,,
albert
Re: my 412
oh,,,thanks for your appréciation,, and the radio is from a vw jetta,,85-90,, 4 speaker casset,stéréo,, 1$ in my yard,, ( spécial price for me ) and the light are the light from ,,bmw,325,, quarts hallogen,, seal beam,5.$ régular price in the car parts store is appx.30.$ each,,and the fender beading are my home made beading,, one strip from the door to onder the bumper,,that need small adjusment ,, the pictures was take in the beginning of my restauration,, and i have a lot of detail to finish for this winther,,albert
412s2
Re: my 412
Why no picture of you standing next to your pride and joy? You have done an amazing job on it Albert and I love the thoughtful improvements you are implementing!! Inspiring stuff!
Bonne route!
Neil
Bonne route!
Neil
albert
Re: my 412
albert
Re: my 412
yes,,lahti411 the rear seat is foldable,,the 190 foam padding and the latherrette are fix on the 412 frame,,the picture was take wend i doo the first test ,, the last adjusment was not finish ,,,albert
Lahti411
Re: my 412
The rear backrest looks really great and fits like it was made for this car. Did you use Mercedes-padding also for the rear seat-cushion? What about the front seats. Are they still foldable? I believe Audi 200 was available only as 4-door model, so i guess it didn't have foldable back-rests. Are you going to relocate the battery to the front boot? Anyhow, the result looks great and the leatherette looks very "period". Lots of work to achieve original, subtle look with desired extras!albert wrote:yes,,lahti411 the rear seat is foldable,,the 190 foam padding and the latherrette are fix on the 412 frame,,the picture was take wend i doo the first test ,, the last adjusment was not finish ,,,albert
albert
Re: my 412
yes ,,lahti411,, the front seat too,, are foldable,,only one screw to remoove each side for the possible foldable on the audi seat ,,but we have need to use a jetta or golf lock ,for to lock,,and you have a slut in the audi frame ( like the 412 ) for the lock handle,, and yes the battery now is in the front truk,,i prefair that for 2 reasons,, one, is for the acid vapor in the car ,,like the audi too,,,but on the audi we have a small tube on the battery for the vapor suction in the charcold filter,, and the secon reason was for my électric seat,the électric union for the battery extention wire onder the front seat can serve for to put an ,,antitelf,,and the power ( with a fuse ) FOR THE FRONT SEAT,, albert
albert
Re: my 412
in the ,,monwest.com ,, gallerie personnels,,bb412,, i have show my new spark plug seals,,plus a plant for intermitent wiper for the old vw,,the spark plug seals are an ,,audi seal for sun roof drain pipe,,
Lahti411
Re: my 412
Which seal/boot did you use to make this neatly fitting filler neck boot? Looks great! Mine is perished and i should replace it soon.
albert
Re: my 412
oh for this pict,, the seal is from an ,,audi 100-200 86-91 ,, for the big main wire who cross the fire wall for the cpu,,i geeve the pn wend i find on my,,,cd,,
albert
Re: my 412
sorry,, for the pn audi,,audi cataloge name that gromet for ac pipe,,
