Does anyone know the diameter of the door pins?
Have a new lathe, need to play with it
thanks
door pins
- Kubelmann
Re: door pins
That is a good project. I could use some of these for the all numerous hinges I have. Let me know how they turn out. I happen to have a few NOS new OE Thing hinges with pins. The pin is 6mm diameter or .238" and the pin is 32.5 mm long or 1.28"
- Kubelmann
Re: door pins
Did you ever make any hinge pins?
- Kubelmann
Re: door pins
Did you ever try out your lathe on the door pins?
CalLookVWs
Re: door pins
Hope he didn't have an accident with that new lathe....
Bruce2
Re: door pins
Making hinge pins on your lathe is a waste of time. The stock ones are hardened. Whatever you make will be too soft.
- Kubelmann
Re: door pins
No the rolled hardened steel pins are drivin into the hinge hole
