turbobaja wrote:That's going to be a really clean install, I like it. I couldn't figure out how your intake mounted up at the T-body in the first pic, but the o-ring seal you described sounds like a great way to make it work. I hope the pipe throught the shroud doesn't cause any head temp issues. Maybe put a restriction of some kind inside the shroud on the 1-2 side to even out the flow and head temps...if it is even a problem.
Best of luck to ya this race season!
I am running E-85 pretty much exclusively for now, so I'm thinking head temps won't be high no matter what I do, though the evening things out idea might be a good one.
There is a tab that is welded to the pipe that mounts up to a hole on the back side of the TB, the hole is where the idle valve holder used to go. I never saw any signs of leakage at the tb, like I did at the unclamped stock rubber boots. Never ran a whole lot of boost though either. I don't think I'll be afraid to turn it up this year though.
The new header will put the turbo in the exact same spot as the CB hideaway, just no piping around the back of the car at all, I don't have it yet, that's why the pipe work isn't quite done to the turbo. It will have one piece of silicone visible, that'll be the one at the turbo. Then the whole system will be tigged up, and coated/chromed/painted, I'm not sure yet which. I'm hoping to run a cold air intake of some sort, possibly into the fender well, I'm tired of high intake temps due to pulling air from a warm (closed decklid) engine compartment.
