can this be an issue?
i asume "lube-a-lobe" style lifters with lube hole in the lifter's surface are recomended for this application?
Dry sump and lubrication og the cam/lifters
- fastback
Re: Dry sump and lubrication og the cam/lifters
I ran dry-sump on circletrack race motors for years without a single cam/lifter failure (with conventional lifters). Must be an ample supply of lubrication thrown off the crank...
The running oil level in a wet-sump engine is well below the cam anyway.
- fastback
yeah lot's of people run drysump without any issues.
have'nt checked where the oil level lines up in the WBX engines, but thought maybe the lobes dipp'ed into the oil
- fastback
took a quick look at it tonight and the oil level seem's to reach pretty high accordign to the dipstick.
- fusername
when its running hte level drops, BUt that is still pretty high, a bit more than i thought.
