2110 cc will sell as whole or part out
nunit
have a 2110cc motor im just tired of aircooled going water cooled
82x90.5
the block is std std but is warped on the top sealing seam from a welded crack leaks a little lol
82mm empi crank std std
5.4 i beams
90.5 b aa pistons and liners
engle 110 cam and lifters
o41 heads 40x35 valves 51 cc chambers ported exhaust and intakes
empi hpmx 44s with 34 vents 150 mains and 50 idles also have some various jets and vents
welded fan
have hex and twist linkage
the motor currently runs
ill also throw in the airtex fule pump
12.5 pound flywheel
the clutch is toast though
will sell whole for 1800 plus shipping
or will tear the motor down and part out if i can drum up enough interest
im located in lower alabama 36323
was going to turbo it so unless you want my homebrewed exhaust you will have to get your own
text for pics 334 488 1212 or call
82x90.5
5.4 i beams
welded fan
12.5 pound flywheel
- CopperBaja
Re: 2110 cc will sell as whole or part out
Location helps...or put it in your profile for ease of use.
96 Pathfinder 4x4 - Family Offroader - 6" "Lift" (2" coil lift + 4" Sub-Frame Drop)
nunit
oh right im in lower alabama yeehaw
nunit
nobody is interested in some stroker parts the carbs are already sold so if your interested in a certain part let me know
tikotiko
How much for the pistons and cylinders and heads
davehix
how much for the crank?
nunit
200 for the crank and rods
and 450 forthe heads pistons and cylinders pm for negotiating and shipping etc
Getbackontrack
Hi I will take the crank and the rods.. I might be interrested in the cam as well (pm me price)
Can you ship to Europe?
Please Write me a mail with payment details..
Regards, Jakob
Regards, Jakob
nunit
where in europe
Getbackontrack
Denmark.. I pay for the shipment offcourse..
Please pm me details, then I transfer you the money up front...
Regards, Jakob
Regards, Jakob
nunit
looks like shipping will be around a hundred dollars
id like to have the heads sold too any reasonable offers will not be refused i dont want to tear the motor down im trying to gets some funds up for a watercooled motor
nunit
i found a k24 locally for 600 dollars and only thirty thousand miles on it i need these parts gone heres a price list
crank and rods 200
carbs 250 linkage manifolds included
heads 300 includes ratio rockers and stock
lightened flywheel 75 includes hd gland nut
pistons and cylinders 110 dollars
i also have a set of 90.5s fora 1776 that needs rehone amd rings 50 dollars
crank and rods 200
Getbackontrack
So you dont want to sell the crank and rods, or?
nunit
just letting you know about the shipping how did you plan to pay
Getbackontrack
I transfer the moneyto your account, and you send me the goods...
Please write me a pm with details.
Regards, Jakob
Regards, Jakob
