Rear shocks for a 411
- 4-eleven
Hello, does anyone know what KYB shocks fits the rear of a more or less standard height 411 Variant?
albert
Re: Rear shocks for a 411
you can find,,many old post for that here,, but,,you can see 4 pn, for original shocks,2 models for the 411 and 2 models for the 412,, they are différent for the wagon, on my wagon 412-73 i have the monrow,,59554 0r 59555, gas adjust,, and they work very well,, but kyb are excellent too, like ray can said,,albert
- Bill K.
KYB 5406 (Ford Econoline 3/4 ton) or KYB 5410 (Ford 1/2 ton) both fit. I used the 5406 with stock 412 "blue stripe" rear coils on my Coupe and I'd recommend them for a Variant with "yellow stripe" coils also.
The lower mount needs shims in-board/out-board to center the mount inside the trailing arm shock bracket. The top mount uses stock 412 parts.
with 205/50/17:
with 205/50/17:
- sharkskinman
what breaks are those???
- Bill K.
* 20AE Golf rear calipers (38 mm) with 944 vented rotors (20.4 x 290 mm)
see http://www.shoptalkforums.com/viewtopic ... 2&t=127810 for more pictures
