Greatplainsas.com sells a T4 kit with 71 stroke 103 bore (2400cc)
I would think that for a low RPM aircraft motor you would want max stroke for more torque. The one I'm planning to build is a shoft takeoff bush plane (big slow prop). I know on Jakes webpage he says theres no need for 103mm, the same power can be had with smaller displacements and the proper combo, and some people have said 103's are prone to cooling problems.
What are your thoughts on a 84mm stroke and stock 94 bore?
I'd like to use stock 2.0 3 bolt intake heads if possible.
Lets hear some ideas and opinions
