biggest crank stroke in 1.9 DH case?
66 deluxe
Post by 66 deluxe »
Ok, i would like to know what is the largest stroke crank i can fit in a 1.9 DH case i will clearance the case myself. I ask as a friend is heading to the US soon and is stopping in at DPR to pick up some cranks i will be geting a 82mm type 1 crank for a type 1 2275 build i am doing as well as a WBX crank just need to know what the biggest WBX crank i can fit will be. the WBX crank will be used in an oxybuild.
Cheers Damo.
buildabiggerboxer
Re: biggest crank stroke in 1.9 DH case?
Post by buildabiggerboxer »
82mm vw journal, 86mm chevy journal.
66 deluxe
Post by 66 deluxe »
82 vw journal it is then will just use standard 1.9 main journals.
