Msd ignition with crank triggering
tufty65
Post by tufty65 »
I am currently running the exact set up below with the magnetic pick up distributor.
Ive noticed it also gives you an option to plug an msd crank trigger into this set up.
The crank trigger is a flying magnet style trigger.
I guess you still keep the distributor and lock it out.
Has anyone used the msd trigger wheel or have photos of one fitted ?
Is there any other trigger kit which will work on this set up ?
I'm running a scat billet sand seal bottom pulley on a 2332 type 1 CB turbo/efi
Thanks.
sagaboy
Re: Msd ignition with crank triggering
Post by sagaboy »
Is the "Boost Timing Master" part of the MSD?
Dale M.
Post by Dale M. »
sagaboy wrote:Is the "Boost Timing Master" part of the MSD?
Believe its a add on optional box...
Dale
