wasserboxer mv with turbo, how?
jabcok20
Post by jabcok20 »
Hello. i;m from Poland and i have beetle'73 . I have 3 engines boxers from vw t3. it's type 4 2.0
type 5 DJ and type 5 MV. type 5 MV . Only Mv is in good condition so i want put it in to the car.
And my question is. where can i make oil supply to turbo?
i must drill a hole or can i make Y tile in hole from sensor?
sorry for my english.
Can i leave engine like he is and just put turbo( i have it from japanese car 2.8 litre).
Steve C
Re: wasserboxer mv with turbo, how?
Post by Steve C »
Hi
When I had a turbo WBX I took the oil supply from the rear most oil light switch with a T piece.
Steve
jabcok20
Post by jabcok20 »
so you suggest give T piece beetwen sensor and hole. ( if i properly understand ).
Do you make any modification with engine for turbo, and how many PSI you serveto engine.
Do you betray mi what turbo you had.
Steve C
Post by Steve C »
Hi
I used a VDO T piece, which is actually hexagonal brass, I then ran a braided line to the turbo
My motor was a DJ, so stock it was 10.5:1, I dropped it to 8:1 using MV pistons with a bit more cut out of the cavity in the piston
I ran about 15 psi, I sold the car before it was properly developed.
Turbo was IHI RHB6.
Steve
Passatman
Post by Passatman »
Good day Steve,
I have a MV code engine and i recently bought some pistons to do a rebuild. Could i run a turbo on my engine without lowering the compression, i understand that the stock compression on a MV code engine is 9.0 : 1. I am thinking of using a holset HX35 turbo with low boost.
Steve C
Post by Steve C »
Hi Passatman
You should be able to get away with running low boost, there is probably more knowledgeable people on here that can tell you more on that subject. I also ran a water to air inter cooler and after market EFI.
Steve
jabcok20
Post by jabcok20 »
I have that turbo from isuzu trooper 97HP but i think it can be too small:(
http://www.aliexpress.com/fm-store/2015 ... -97HP.html
i read somewhere tha ihi rhb6 is "japanese" T3
Joe vw
Post by Joe vw »
The best simplified turbo conversion requires a mid 1980s Saab or Volvo turbo car with Bosch LH 2.2.
Install the whole system onto a stock MV waterboxer and it adapts perfectly without any glitches.
I have been running mine for about 1 year now and it gets better than factory milage and makes tha vanagon fun to drive. It peaks around 9 lbs of boost and even without an intercooler does not ping. Torque comes on pretty early in spite of my mild performance cam.
In fact, the original stock cam would have been smoother and worked fine.
The hardest part is removing the whole injection harness from the donor car and rerouting it to fit your vehicle. You must have the whole donor car. Wiring diagrams are on the internet.
The other part of the equation is fabricating the turbo exhaust and intake plumming. Keep your turbo high enough to drain back naturally. I put mine on the right side the of engine and fabricated my whole exhaust system.
Passatman
Post by Passatman »
Could you post some photos of your setup.
Joe vw
Post by Joe vw »
jabcok20
Post by jabcok20 »
Joe , your turbo is from saab/volvo with those electric instalation This turbo looks small. What type is it?
jabcok20
Post by jabcok20 »
i found something like this:P
turbo holset h2a from volvo 5.5 litra i guess.
Uploaded with ImageShack.us
is this worth to put it to stock wbx? offcorse with bigger injectors and new engine computer:S
