The rough outline for the new motor:
T5 case, shuffle-pinned, T1 lifter bores
forged 82 or 84 crank, chevy journal
94 lightweight forged pistons, weisco or the like
h-beam rods with arp bolts
Aggressive turbo cam with 4000-8000 power band
straight cat gears, cb perf. if they work
MS3 engine management
autocraft dry sump pump
borg warner efr or garrett gtx turbo
worked heads, equivalent to wedge ports with cb650 or k800 valve springs
ceramic coatings on pistons and heads
low friction coatings on bearings and cam gears
I'm aiming for 650hp+ peak then dial it back to 3 settings, low boost ~300hp, high boost ~400hp, and scramble boost ~500hp. This is a circuit car that will spend 20-30min on the track at a time with about a third of that time in boost above 5000 rpm. I've seen crazy hp numbers coming of these engines and I'd like to try it myself but what I need is a little help on the particulars. I can start with a 1.9 or 2.1 case which ever is easier and go from there. Crank and head work I'm not sure about, same with the piston/cylinder combo. It's got to mount to a z-case type 1 tranny for now, and the case should hold for road course use.
I've I can get this built soon enough I'll have a turbo 2165 for sale
