I just bought a "project" bug and it has 1/2 finished Cal windows in the doors and I have no clue how to finish it. If someone can please point me in the direction of an article that has a walkthrough or an install guide that would be MUCH appreciated!
Going from this
To this!
71 Cal/Euro look door window install help
- wrenchnride247
Re: 71 Cal/Euro look door window install help
"Cal look" windows are the rubber seals without the metal trim groove. If you are talking about "one piece" window kit... from what I see in the pics, nothing has been done yet. Need more details please.
I am sorry, I did not post the pics of the doors without the vents. Yes, I am speaking of the "one-piece" windows.wrenchnride247 wrote:"Cal look" windows are the rubber seals without the metal trim groove. If you are talking about "one piece" window kit... from what I see in the pics, nothing has been done yet. Need more details please.
You'll regret it...and that's not just my opinion.
http://www.shoptalkforums.com/viewtopic ... 18&t=84221
- wrenchnride247
If the small sheet metal section has not been cut out of window channel then go back with the stock vent set up. The one piece set up WILL leak... unless you never drive in the rain I've had them on my bug for 18 years now. If you have a good vapor barrier behind your door panels, and the drain holes in the bottom of the doors are not clogged up, it wont be to bad...
One more thing... make sure you have the "snap in seals" and not the ones you have to screw in place if you go the one piece route anyway.
