Turn signals
cowskey
Turn signals
Post by cowskey »
73 Westy. When I make a turn both indicator lights on the dash flash. Is this normal?
Re: Turn signals
Post by Marc »
I presume you mean when you signal for a turn, not that they're coming on by themselves when cornering...
Yeah, both indicator lamps are wired in parallel. I altered the wiring on my`73 Squareback to make them independent - but that makes them no longer function when the 4-ways are on and the t'signal switch is in neutral, so the lamp in the hazard switch knob is the only indication.
