Is this a KG windscreen seal?
carl4x4
Post by carl4x4 »
My car had no windscreen when I bought it, but there was a box of assorted spares, this one piece rubber seal is I'm hoping the windscreen seal, anyone know for sure?
thanks
Re: Is this a KG windscreen seal?
Post by Marc »
It may be, but there's no way to be sure without knowing what it measures out at. Assuming that it is `Ghia, there's `56-early`66, late`66-`69, and `70-`74. I don't know for sure if you can positively identify which one it is by the single trim groove, but someone here might.
sideshow
Post by sideshow »
That looks like "cal-look"'ish seal to me, I don't see a groove for the late T-trim or early C-trim.
I personally test "known to be ghia" seals by wrapping them around actual ghia glass, but any non-blocked seal fit is not always apparent.
carl4x4
Post by carl4x4 »
OK thanks, I don't think it would be an older Ghia window rubber as the place I bought it from didn't specialise in Ghias. It does seem to have a slot for the chrome trim, probably not noticeable in the pictures though.
