I have a whole long axle set up. I bought the trans just for the gearing and swapped my short axle set up on it. It includes everything to bolt to a trans. The only thing you'll need are the nuts to bolt the tube to the trans.
Long axles
Long axle tubes
Backing plates
Axle bearing caps
Hardware to attach axles.
Bolts to the bearing caps
Inside and outside spacer for the bearing and drum.
$75
located Mio, MI
long axle swing axle set up
- durfeec
1981 Brazilian 14 Window
