hello,
I'm Bart from Belgium,
I'm building an oxyboxer.
I have a little problem with an oxyboxer engine case.
I removed the waterjackets and now i can see a mark of a plug from an oil galery.
see the pictures.
do I have to remove it or can I leave it like it is.
I am affraid that it will pop out by the oil pressure.
greets
bart
oil plug oxyboxer
vanholle
oil plug oxyboxer
tencentlife
Re: oil plug oxyboxer
That's directly off the main oil galley, when you start up cold it will have 80+ psi behind it. And you've milled away at least half of the plug. So what to do depends on how lucky you feel.
Pål A.F.
I pulled out mine on my oxyboxer project. Will put in a threaded plug instead.
- fastback
a good reason to pull the other plug's also , to clean the galleys well.
vanholle
thanks voor the advice,
I removed the plug.
I removed the plug.
