Except Pete at airkewld isn't making 4-bolt rotors anymore. I even tried to get some rotors with a blank pattern so I could machine them myself, but no soap. So I decided to make my own, including the design. Pete's 3-piece design with swappable wheel bolt patterns is cool, but I don't care much for changing wheels so I decided to make mine 2-piece. While I did the design myself, my friend Nacho is the machinist at our shop and he did all of the work on the hubs for an undisclosed amount of cash and a case of MGD. I was finishing my last quarter at school, so it was nice to have the car worked on without actually being home.
Starting with two 6.5" billets of 7075 aluminum and 1/2" plates of hot-rolled steel.
I drew up the rotor pieces in CAD and had them waterjet cut. I made six rotors total.
Blanchard ground to the proper .375" thickness. I countersunk the holes for flat-head bolts.
Rather than pay the waterjet operator to cut the holes, I made an identical rotor (1/8" thick) on the plasmaCAM we have at our shop with the crossdrilling in place. I reamed them out and then used it as a pattern to drill through the real rotors. Now I also have something cool to make a background for a garage or shop clock.
Here's Nacho scraping off the outside to the final diameter.
I don't have any progress pictures of the hubs, because Nacho lathed them while I was still up at school. So jump ahead with me:
Then I had the hubs hard-black anodized, while all the rotors got a nice clear zinc coating. After that, I pressed in the bearing races and wheel studs, and we're all set.
I haven't put them on yet. I got some stock disc backing plates that I want to add 2" vents onto for ducting before I bolt these on for good. I have to re-weigh these again for the official figure, but they came in around 11 pounds, which is about 3.5 # lighter than the stock cast iron. Not as much weight reduction as I had hoped for, I suspect I could have used less steel in the spoke design. But I had a lot of fun making them.
The only regret I have is that no one will ever see them! These are my wheels:
