looking for good machine shop in the detroit / toledo area
apba12m
post says it all. I am rebuilding my 74 thing motor to basically stock and need to have some machine work done. any help would be appricated..
Stray Catalyst
Re: looking for good machine shop in the detroit / toledo ar
I've found that the best bet is to find a good shop and send it there. ACE, MoFoCo, and a variety of others have good reputations, a,d the amount you spend in shipping will be far less than the cost of fixing the botch done by a local shop that doesn't actually know what they're doing.
http://www.aircooledengineering.com/ reground my crankshaft, I can't speak highly enough of them.
http://www.mofoco.com/ did my connecting rods.
http://www.qualitygermanautoparts.com/ sold me my case after the previous one that I'd hoped to use didn't work.
Stray
Stray
RWK
What do you need done? I can do case/head milling, drill and tap oil galleys, clearence for stroker crank, all done on a cnc mill with proper fixtures, cut to case center line square and parallel and equal both case halfs to maintain equal deck height, heads hemi cut also, I do not line bore. PM me for more info.
rwk
rwk
madmike
Can't tell you about Detroit area since I moved North 250mi
But There is a few places in lower mi,like Greens' near lansing I think,D&R Buggy in Rose City 989-685-2821 there's a few around Grand Rapids too check out www.thegoodvolks site and I'm sure you can find someone close to you,Madmike
- nsracing
I am in northern VA. I do linebore, machine work and balancing. Full engine builds when time permits.
let me know if I can help you.
art.b
Are you in Livingston co?? Pm if you are. Top quality Vw trans guy and machinist available.
