Pedal Cluster lubrication?
Max Welton
Post by Max Welton »
So I've cleaned up and painted my pedal cluster components. Ready to reassemble.
What sort of grease should I use?
Max
sideshow
Re: Pedal Cluster lubrication?
Post by sideshow »
I use wheel bearing grease. I have noticed that really early pedal assemblies (no pedal pivot) have zerk fittings so I suspect that front end grease is also OK.
Max Welton
Cool. It has been suggested to me that Bosch distributor grease works good too.
Max
Max Welton
Reviving this thread after a year.
The distributor grease has not proved to be a long-lasting solution. Does someone have a picture of how a grease-fitting would be done?
Max
Post by Marc »
You'd just need to drill & tap a hole in the top of the casting for the zerk, with a small hole going through the steel tube to get grease to the clutch shaft. A second hole in the tube outboard of the casting will let grease come out to reach the brake pedal. A 90° zerk can make for easier access. For a street rig, you shouldn't need to do this - wheel bearing grease should be sufficient for about 10 years....
http://cma-vw.com/store/articles/HotVWs_2011-08.pdf (pic on page 6 of 6)
