How do i do this in a good way ? i have a spare one that i want to use as one of two triggers in my upcoming ms install on my rallycross wbx engine.
Regards
Dann
full lockup of vacuum/centrifugal advance of DJ distributor
riseabove
Re: full lockup of vacuum/centrifugal advance of DJ distribu
The cleanest is sell the nice 1.9 distributor and replace it with a 2.1. It is already locked, and about half the height.
Steve
My Baja Build
My Baja Build
Your 1.9 dizzy has more value than a 2.1. Don't wreck it by welding the advance.
Steve
My Baja Build
My Baja Build
riseabove
But my 2.1 distributor from a "DJ" engine has vakuum advance in it. the bosch part# for the distributor is 0237 022 053 if that helps.
Regards
Dann
Regards
Dann
Europe got different combinations...
The late model FI version we got has no mech or vac advance, it's just a trigger.
The "full featured" setup you have should stay together and working as it's a HUGE upgrade for anyone sticking with carbs.
riseabove
but what about if i have a spare distributor just lying around from a previous engine ?
anyone have pictures of where to weld or what to do ? i WILL keep my complete injectionsystem as a unit complete with wiring harness if i ever want to go back to digijet....
- sideshow
You can safety wire the weights w/o ruining anything. Same could be said for a drop of JBweld or like epoxy.
riseabove
i will that a try and hope for the best then
Regards
Dann
Regards
Dann
tmatre
This is how I modify my distributors.
http://forum.earlybay.com/viewtopic.php ... 6&start=80
riseabove
THANK YOU !!! this was EXACTLY what i was looking for !!!tmatre wrote:This is how I modify my distributors.
tack så mycket , jag visste att någon nordisk människa skulle komma med lösningen till slut ! tackar varmast från Sverige !
Regards
Dann
