Electric fuel Pump 76 Westy 2.0fi
MrGolf
Post by MrGolf »
Think my fuel pump may be bad. Under load it runs rough bucks a little. Give it gas and it stumbles. Not smooth. If I remember right when I use turn the key on I would hear the fuel pump start. Now I hear nothing. It will start after rolling several times and does not idle real good. How can I test the pump to see if it is working ok. Plugs wires cap rotor are all good. Just put petronix in last night. Still have the problem. Have only put 347 miles on it since 4/2008. Any suggestions would be appreciated. Bad injector maybe????? How would I check that? Thanks
Jadewombat
Re: Electric fuel Pump 76 Westy 2.0fi
Post by Jadewombat »
Put a fuel pressure gauge on it and watch the pressure. Check the return line for amount of fuel volume as well.
http://www.ratwell.com
