Hi Guys !
I have the complete engine harness and Digijet boxes all connected together with the original T3 engine harness, now for the interresting part, how do i wire it all up to my 1303s existing wiringharness?
Guess that this info is somewhere here on the forum to be found but i have yet to find it... please help ?
Regards
Dann
how to wire in my 2.1wbx DJ engine in my vw1303
riseabove
Rallycross-style 1303 Wbx 2.1
Fully adjustable homemade coilovers , solid rosejoint fully adjustable camber/casterplates by own design
and so on... all performance mods are homegrown
westypoo
Re: how to wire in my 2.1wbx DJ engine in my vw1303
best advise i can give is you need to get the wiring diagram for a vanagon WBX digijet. i just put one in my super beetle as well (1303), BUT im running mine on megasquirt. BUT if you get a Bentley repair manual, you can look up all the power/ grounds for the injection itself, and then mark thoes wires and hook them into the power/grounds into the bug itself. sounds a lot harder then it really is. if you can post up pics if the diagrahms, ill do my best to help ya out.
btw, i read your sig, got any pics of the stuff you build and of your car?
riseabove
i have a complete wiring diagram for the digijet, as far as i know there is only 2 wires that i need to connect to the actual beetle harness , power for the injectionsystem and the cable from the injectionsystem to the electric fuelpumps relay.westypoo wrote:best advise i can give is you need to get the wiring diagram for a vanagon WBX digijet. i just put one in my super beetle as well (1303), BUT im running mine on megasquirt. BUT if you get a Bentley repair manual, you can look up all the power/ grounds for the injection itself, and then mark thoes wires and hook them into the power/grounds into the bug itself. sounds a lot harder then it really is. if you can post up pics if the diagrahms, ill do my best to help ya out.
i hope that i will get this together later next week as we have a big vw meeting in 2 weeks that i want to attend with my car
- fastback
If u get hold of this connector from the engine harness , it wires up like this:
thick RED= +12v battery
Black w/ yellow connector= switched +12v
from the multi connector:
Red/black = signal from the starter solenoid(to start the fuelpump when cranking)
Brown = Ground
Brown = Ground
riseabove
fastback wrote:If u get hold of this connector from the engine harness , it wires up like this:
RED= +12v battery
Black= switched +12v
Brown = Ground
Once again the nordics come to my rescue ! THANK YOU so much TACK TACK TACK TAKK
- fastback
