As the title says, I'm after a bit of advice for an engine for my bus. I haven't been on here for a few years so now can't figure out my old user name and password! So starting over!
I have searched and have now read every post from the last 3 years where anyone had typed "bus".
I've narrowed down a few things, but am really open to suggestions on basically all parts of the build. So far I have a CB hideaway turbo kit with the T3/4 turbo, 48mm throttle bodies, and have the crank trigger ignition kit to go with it. I had an engine I was going to rebuild and add this lot to, but that engine went in another bus and has now been sold. So I'm going all new with the longblock, so need to make myself a shopping list seeing as I have bought nothing for it yet.
The engine is going in a split bus, it has a couple of rows of seating in the back, so not a heavy camper. It's not going to be a daily driver but will get used as much as possible. Will probably never see any strip action, but that would be quite funny to do if I got the chance!
For size I thought of doing a 2275, but then could also do a 2110 to use the 90.5 pistons to keep to heat down a bit. Or is there not much difference in the heat from a 90.5 compared to a 94 piston? I'm also going to be adding a water/air chargecooler set up and an external oil cooler as well.
So open to ideas on engine size, head and cam choice, valve sizes, basically anything that will work well in a bus to make good torque (even on off boost cruising).
I have a pair of valve covers, just need to fill the gap between them!
Cheers, Daniel.
