I'm posting this topic because i need help to figure why i don't make more then 0,9bar on my 1.9L WBX engine regardless rpm. I know there are some guys out here running turbo charge WBX engines and maybe you can bring new light to this problem.
Engine facts:
Stock WBX 1.9L DG (fully restored with weighed pistons, etc)
Stock intake
Stock typ1 camshaft and hydraulic lifters
Holset Hx35 twin scroll turbo housings with internal Wastergate
685cc fuel injectors, Runs on E85
Megasquirt with Edis
Homemade 38mm exhaust with twin scroll
64mm down pipe (exhaust back pressure before turbo housing follows the boost pressure)
The engine starts to load app. somewhere between 2500-2800 rpm and the boost increases with the rpm in a linear way. And when i get to 5500-6000 rpm i have 0,9 bar of boost. I have pressure tested my intake and sealed every leak. I try to disconcerted wastergate but no difference in boost pressure.
I´m planing to rebuild the engine this winter and do some modification such as install bushings so i can use typ-1 lifters, bolt on a 1.25 rockers and put on a intercooler.
/M
