1970 Beetle
crucial
1970 Beetle
Post by crucial »
0 miles on NEW engine (everything except the intake is NEW/rebuilt) including a Weber carb, NEW ceramic coated dual quiet pack header and muffler, NEW coil, alternator, and fuel pump. Super clean interior with all NEW back seat, door panels, stereo and cargo area carpet. Completely re-wired with every wire, relay and switch replaced. All NEW lighting with flush 32 Ford LED tail lights (brake/turn/running lights in one) in the rear, and NEW headlights with integrated turn signals/running lights in the front. The stock turn signals have been shaved. Early style chrome blade bumpers. There is no rust to be seen on this car, body is straight paint is good, lots of rubber on the tires and a NEW matching spare wheel (I have 2 extra tires as well).
CLEAN TEXAS TITLE
No trades, no shipping, cash only!!
Asking $8500 O.B.O.
Call me at 817 Five Zero Zero 4 Nine four 5
Thanks for looking,
-Dave
See below for extended details
_____INTERIOR_____
• NEW Sony MP3/CD player w/detachable faceplate,
• Polk Audio kick panel speakers,
• NEW Wiring Harness (every wire replaced),
• NEW Turn Signal switch,
• NEW Dash Switches and relays,
• NEW Back Seat padding and upholstery,
• NEW Door Panels,
• NEW Carpet in Trunk and cargo areas,
• Front bucket seats from Honda Accord (upholstery matches rest of the interior),
• No rips/holes/stains in headliner,
_____EXTERIOR_____
• NEW '32 Ford LED tail lights w/brake/running/turn lights,
• NEW Headlights with integrated running/turn signals,
• Shaved turn signals front/back,
• NEW Early style chrome blade bumpers,
• Empi 8-spoke wheels (including NEW spare),
• Lowered front adjustable/narrowed beam,
• One-piece Windows,
• Good Pans, no rust anywhere that I can find,
_____ENGINE_____
• Long block built by Troy Goodwin,
• NEW Distributor w/electronic ignition,
• NEW Bosh Coil,
• NEW Battery,
• NEW Weber Carb,
• NEW Fuel Pump,
• NEW Alternator,
• NEW Plug Wires,
• Relocated Fuel filter,
• NEW Ceramic coated dual quiet pack header and muffler,
• NEW Throwout Bearing,
• NEW Tins,
• NEW Doghouse style oil cooler,
• NEW Fan,
• Single Relief Case,
• Fresh Align Bore,
• NEW Mahle Main Bearings,
• NEW Koby Rod Bearings,
• NEW Koby Cam Bearings,
• NEW Mahle Pistons 85.5,
• NEW Mahle Rings,
• NEW Mahle Cylinders,
• NEW Mahle Wrist Pins w/keeper,
• NEW Push Rod Tubes,
• Fresh Turned & Polished Crank,
• Reconditioned Rods,
• NEW Oil Strainer,
• NEW Gasket Set,
• Repainted Valve Covers,
• NEW Air Deflectors,
• Reconditioned Rockers,
• NEW Oil Pump,
• Dual Port Heads,
• Reconditioned Intake Valves,
• NEW Exhaust Valves,
• Reconditioned Flywheel,
• NEW Main Seal,
• End Play Set,
• NEW Chrome Pulley,
• Deck Hieght .050,
• Head cc's 52cc
