2332cc Buggy or Baja engine turnkey.
AK series T-1 case, .020" align bore, standard thrust.
New 84mm forged crank, Buick/Chevy rod journal, all standard.
94mm AA piston kit.
5.500" H-Beam Rods
Web Cam 00-312 Camshaft w/HD lifters
Scat pushrods
CB straight cut cam gears.
CB racer spacer
Schadek oil pump full flowed.
Chromoly 12-1/2# flywheel.
Chromoly Gland nut.
Chromoly head studs.
Black laser engraved sand seal pulley.
Brothers Machine 40x35.5 cylinder heads.
Dual 44 HPMX Carbs with billet air cleaner assemblies, crossbar linkage and outerwears.
1-5/8" EMPI chrome header with turn down.
52a alternator.
009 distributor w/electronic ignition.
Taylor 10.4mm performance plug wires.
Add your clutch and pressure plate and it's ready to go.
Very low hours, we built this engine in house May of this year.
$3000 OBO, interesting trades considered.
2332cc Engine
- turboblue
- Leatherneck
Re: 2332cc Engine
Sounds like some good parts, along with the master who put it together it should be bullet proof. Any pics? Good luck Gary.
- turboblue
Re: 2332cc Engine
Leatherneck wrote:Sounds like some good parts, along with the master who put it together it should be bullet proof. Any pics? Good luck Gary.
Not yet David.
The sheetmetal the guy had we put on was used.
Need to clean it up before I put up any piccs.
