Speedo delema
Need help installing a stereo or other interior item? Come on in!
ouvw2
Speedo delema
Post by ouvw2 »
I have a small problem that i need help with. I dropped my bug using cb drop spindels. after installing them i realized that there is no provision for the speedo cable, not that it would fit because of the arms arms are in the way. what did you guys do for a speedo after doing this. I have a cool 914 speedo I would like to keep. any ideas.
Randy
Re: Speedo delema
Strange, I installed CB drop spindles on my 68 and it still had a speedo cable...
Check the US driver side spindle?
If RHD you may need to make up a custom cable, if rhd setup uses the r side spindle..
ouvw2
Re: Speedo delema
Post by ouvw2 »
i ve decieded to just use the speedo down load on my cell until I can figure this out. thanks
Max Welton
Re: Speedo delema
Post by Max Welton »
I have seen GPS speedometers for such things as marine applications.
Max
