Weddle Pro 4th gear set for 113 or 002 transaxles. Has tig welded syncro cone and a flawless hub engagement tooth profiles. The gear set has 6000 miles of use from a Baja style street car. My transmission shop, RUSTY BOTTOM GARAGE in SMRYNA, TN, gives it a clean bill of heath. Reason for removal is that I had an higher ratio gear set installed.
