The driver's side lock on my '71 Ghia is not unlocking the same way as it used or as the passenger side does. Normally, pulling or pressing the short upper lever allows you to lock and unlock the door latch, and you open the door by pulling on the long lower lever.
On my car, pulling the short upper lever unlocks and opens the door in one motion...the longer lower lever is not used. It is a bit more efficient in a weird sort of way, but that is not how it is supposed to work.
Apparently, the door lock mechanisms are no longer made, used ones goes for $100+ (with no guarantee of service life)
Thanks in advance for any pictures or help that you can offer!
