@ Steve: That's a cool idea, never thought of that
For now this inlet will have to do, as the build has taken way too long already
I first started off with a piece of foam, and made one collector between the guide vanes of the Porsche outer ring (alot of sanding, bondo-ing and cursing involved
). After finally finding the right shape, I made a 2 piece mold around the collector, so I could make a serie of collectors. As all 4 collectors are equal, a good 2 piece mold was essential. After that, I made an inner ring, which corresponded with the boltpattern of the Porsche alternator, so I could mount it to the Porsche outer ring. I glued this on the inside of the collectors with epoxy. Finally I used fiberglass weave on the outside all around the Porsche outer ring to get an airtight seal and to keep the collectors together. After that, I made the engine 'tins', using original tins as a mock-up. Again I used foam, aluminium sheet, wood and bondo to get the shape. After that, I laminated another 2 piece mold for the engine tins. I then used aluminium hose to connect the tins to the collectors, and epoxied fibreglass around these hoses (used alot of wax). When the epoxy was dry, I could remove the aluminium hose by unraveling them from the inside.
@Pile: Thanks! The horizontal cooling system is indeed a very nice design. The 90 degree bend in the fanbelt is actually the biggest drawback of this system, but it is very effective.
@Stripped66: Thanks! I was planning to measure the heads at 4 points with thermocouples and maybe 4 more for the cylinders. I still need to do alot of testing and tinkering to optimise the air distribution in the 'tins', and this type of data is essential. As soon as I have some measurements, I'll post it on the STF.
@Greg: Not for the moment. Maybe when I have tested and optimised everything and I have found a way to simplify the process of making the shroud. At the moment it just takes way too much time to fabricate.
Cheers,
Robin
