HELP! Wheel locked up.
Bonemaro
Post by Bonemaro »
I'm trying to get the Ghia on the trailer, but the rear passenger wheel won't move. Brakes? Transaxel?
Any tips?
Jim
My 1973 Karmann Ghia---> http://www.73ghia.com
Re: HELP! Wheel locked up.
Open the bleed screw on the locked wheel to see if there is a problem there. It may relieve the pressure caused by a bad soft hose or a locked up wheel cylinder.
helowrench
Post by helowrench »
Release parking brake.
Had to be said.
Anyway. Park brake off, remove wheel, smack drum with hammer repeatedly
Usually you can hear the shoes retract when they unstick.
helowrench
I have used a drift to get in with wheel still on with varying success
Bonemaro
Post by Bonemaro »
Jim
helowrench
Also. Remove the shoe inspection covers on the backing plate and you can sict a screwdriver in there and directly work on the pad itself
Bonemaro
Post by Bonemaro »
Hammer did the trick. Thanks y'all.
Jim
helowrench
Wonderful.
The technical term is "impact adjustment performed with BFH"
mountainkowboy
Post by mountainkowboy »
helowrench wrote:Wonderful.
ROFLMAO!!!
71 Ghia Coupe........For Sale
71 Super-Beetle Convertible.....returning to DD status
63 IH Scout 80 (beater)
Or... "bang the gong slowly". :twisted:
didget69
Post by didget69 »
Both rear wheels were locked up on the '71 Ghia I just picked up - I backed off the shoe adjusters & used the 'applied physics' method as well.
The BFH... then, on the way home during the 10 mile flat tow, the right front wheel decided to lock up - yoinked the caliper bolts out, pulled caliper &
tucked it into pan recess, then zip-tied it safely out of the way & continued tow home - no problems.
bryan
