Does the Blue Brake Hose have to have clamps or would it be a good idea to use those FI hose clamps ?
TIA!
Does the Blue Brake Hose have to have clamps?
- Jim Ed
Re: Does the Blue Brake Hose have to have clamps?
No hose clamps necessary, the hose fits really tight if you get the good stuff.
Steve
My Baja Build
My Baja Build
- sideshow
I wouldn't clamp that hose, it would only ruin the plastic barbs of the resivor/inlet. The factory didn't.
vwo60
if you intent to have the brakes pressure bleed at any time you can fit clamps to the hose, just do nor over tighten them, I have done this on some of my cars as only power bleeding would give me a good pedal.
Our shop has power pressure bled many thousands of cars and non of them have had clamps on those lines.
Steve
My Baja Build
My Baja Build
