I'm building an oxyboxer 1.9 for my beetle I'm using type 1 pistons and pins and need to turn some con-rod bushes (wrist pins)
whats the best material to use, bronze, p/bronze, brass ?
thanks for any advise, JP
oxyboxer con-rod bushes
Re: oxyboxer con-rod bushes
You will probably discover that simply installing a set of T1 rods is going to be a huge win...
Also available in other than 5.394" lengths, and in multiple styles, for less that the cost of having a set of rods rebuilt properly with new bushings and good bolts.
New bushings are quite thick (so they can be pressed in) and always have to be bored//reamed to size.
justin pane
Hi thanks for the advice,
I have my own lathe, bridgeport, press etc so thought bushing would be most economical,
but I will consider you're suggestions
thanks JD
thanks JD
In that case the stock replacement WBX bushings might ream out OK, depending on ID.
Several folks have noticed that at least in the US, the 311 style 2.1L stock rods get oval badly at the big end by ~100K mikes.
Could be from sustained high RPM use, could be due to the heavier pistons--- not sure why, but have seen it myself.
CrMo rods (H or I beam) should not have the issue, ever.
pocketrocket
Yes T-1 rods can be used, but the pin size on a WBX rod is 24mm and a bug style rod is 22mm. You CAN NOT ream a stock rod bushing to 24mm as the bushing will be to thin. The T-1 rod has to be bored to size that the bushing wall will be no less than .030 finished size IMO. This makes a lot of work to set the rods up bore them to size, make bushings with the correct press fit. Then bore ream or hone to fit the 24mm pins. Rocky
pocketrocket
Sorry, after re reading the first post. I see now what Justin is wanting to do. What comp ratio will you get with no dish with flat top T-1 pistons? Rocky
justin pane
I aim for 8.5 but as I bore out and bush the c/case (after machining flat) I can machine the bushes to any height I want to achieve the comp ratio I want,pocketrocket wrote:Sorry, after re reading the first post. I see now what Justin is wanting to do. What comp ratio will you get with no dish with flat top T-1 pistons? Rocky
but my question was what material do I use for the con rod bushes?
