Not sure if this is the right place to post this but this is a great tool for anyone doing off road fab work.
This is a brand new American made 2"x60" 3 wheel vertical belt sander and stand, this is the only sander needed for metal fabrication, great for sanding and notching tubes. this sander can be purchased with or without a motor. You can sand on the work rest support,the contact wheel,the loose belt area or the flat platen. The stand is 70 pounds and keeps the sander steady for work,the sander body is made from aluminum. Let me know if you have any questions
Sander and stand without motor is $500
Sander,stand and 3hp motor is $800
All parts are new and located in S Calif
Gootjr@yahoo.com for any questions
Belt Sander 2"x60" vertical belt sander
gootjr
