You seem to had plenty of experience with the wasserboxer
Looking through your pic!
Very good!
Are you using the Bugpack pump?
On my turbo application, the oil gallery supply for it comes off a tapped gallery from the main oil pump to filter gallery.
The fitting is a modification through a pressure switch with a brake line fitting attached to it. The oil (brake line pipe) runs down to the turbo which sit under the rear fender. Due to the turbos low level oil has to be pumped back up to the engine case.
After oil runs through the turbo it is collected in a remote sump and the is pumped back to the case, through the old oil filler gallery via an electric scavenge pump.
Do you think this oil line (brake pipe line) that supplies the turbo is big enough to cope with demand?
Do you think this oiling method for the turbo is actually reducing the performance of the main oiling supply to the internals of the engine?
Do you think i should make a separate oil supply to feed the turbo system with separate flow and return pumps?
This i think, would preserve oil temp problems that the turbo creates and also keeping the engines oil temp lower.
Cheers
Paul
