startup and idling issue
jshbrgs07
Post by jshbrgs07 »
After a 60km roundtrip with my 1200cc I had to make a stop over to drop something off. After, the car suddenly had a hard start but started anyways and moved for a few meters it suddenly died out and this tym won't start and after a few tries it started but won't idle and died out.called out a mechanic to help and opened the carb and cleaned the idle jet, increased the air flow and idling. It worked fine till I travelled again for a 30km roundtrip and the issue is back, tried to start it via choke and it worked but I noticed that my consumption of gasoline is really high and the issue is intermittent. Had this issue before and was resolved with the replacement of rotor cap..
TIA
