Bore: 98mm (cast alu cylinders, plasma coated, one-off's) - update: killed those. 98mm birals AA - killed the pistons with those, my bad - now 102mm Deutz cylinders.
Pistons: JE custom ones.
Stroke: 74mm (Oettinger)
Rods: Pauter turbo-spec (heavier)
Heads: TP billet with type 1 port orientation and Ti-valves 48x41
Head studs: Raceware
Cam: Pauter, off-the-shelf - update: JPM113-110LC
Rockers: Pauter billet 1,48 ratio
Lifters: TP type 1 tool steels, light-weight version
Pushrods: TP Dual tapered alu
Oil-pump: TP dry sump 26/38mm
Turbo: Borg-Warner 7670 (same as last years), update: EFR7670 Twinscroll.
Most important job left to get done is having the seats and guides installed. Will have to wait a bit (unfortunately) before I can send the heads out to get that done.
As I am using the same turbo as was on the old 2,20 ltr (103x66) engine, I can't wait to see how the torque lines will compare on similar boost levels.
Cheers,
Walter
