Some say go with the 94's and others say go with the 90.5's. I am not sure which way to go. ANY good technical suggestions would be GREATLY appreciated.
THANKS!!!
You need to decide on what "reliable" means to you. I personally have never gotten the durability out of 94 mm Mahle cylinders that I have from their 90.5 kit (I used them in both Buses and Beetles). The 94 pistons are fine, but for whatever reason the 94 cylinders are kind of a "half-life" product, in my experience. If you plan to drive a lot of miles (e.g. 15,000 per year), then I would recommend the 90.5's.Big Z wrote:I am currently building a "daily driver" Bug and I am trying to decide which engine to build. I am looking for something with as much power as I can get while still using the 69 stroke and standard Dual Port heads and still be reliable.
Some say go with the 94's and others say go with the 90.5's. I am not sure which way to go. ANY good technical suggestions would be GREATLY appreciated.![]()
THANKS!!!
