Balancing rods/pins/pistons - 3 new 1 old :(
mm289
Post by mm289 »
As per my post above on the case, I am about to re-assemble this 1600TP engine. Its just a temporary build to get me through the summer so not trying to spend many $'s.
Engine came to me having had a broken piston in its past, so have split case, thoroughly cleaned, polished crank and about to assemble with new mains, rod and cam bearings.
Engine came with 3 of the original (new) pistons, not sure what they are (pics below if anyone recognises them :)) and one old Mahle.
The Mahle one also has the rod and pin that came with it not the same rod and pin as the other three :roll:
As it was fitted to the engine (which also had a turbo on it at the time - since removed :shock: ) the Mahle assembly (no.4) is 26g heavier than the lightest and 17g heavier than the heaviest of the other assemblies.
By moving pins, rods and pistons about I can get a total variance of 8g and if I did a bit of machining on the piston/rod of the heaviest assembly I could get that down to 4g. (the biggest weight discrepancy is the pin, the Mahle set is 12g heavier than the others).
So question is - is it ok to mix 'n match rods and pistons and pins like this to get close to balanced - doesn't need to be a racer so happy with 4-5g but 26g sounds a bit excessive! :?
Cheers,
MM
Phil69
Re: Balancing rods/pins/pistons - 3 new 1 old :(
Post by Phil69 »
5 grams is VW's spec.
I would check your deck hight's and do a compression test before running the motor but I can't see why there would be a big problem.
mm289
Post by mm289 »
Yeh, that's what I figured thanks :)
If I could find out what make the pistons are I might be able to track down a matching one but I don't recognise the markings at all :(
Cheers,
MM
sideshow
Post by sideshow »
mm289 wrote:If I could find out what make the pistons are I might be able to track down a matching one but I don't recognise the markings at all :(
Have you considered posting pictures of the top and side skirt?
Post by Marc »
Nothing at all wrong with juggling wrist pins (provided their dimensions are the same, of course). I keep a couple of coffee cans full of them just for this purpose. Although 8g is within allowable limits for a stocker, it would be nice if you could get them just a little closer, say within 5g. Failing that, put the closest-matched pairs across from each other (1&3, 2&4). If the oddball piston is less worn (judging by the top ring groove wear and overall appearance) have it end up on #3...if it's the worst of the lot, as seems likely here, put it on #2.
For a low-budget project like this I wouldn't have any qualms about narrowing and/or shortening the piston skirts a little on the heaviest piston(s), either - most "high-performance" pistons come with shorter skirts than those on the cast stockers, so it's not hard to rationalize some judicious whittlin'.
mm289
Post by mm289 »
Thanks guys, will put it back together now,
Will get some pics of sides and crown on tonight.
Cheers,
MM
mm289
Post by mm289 »
Couple more pics of the pistons I'm trying to ID
Cheers,
MM
