1600 to 1835????
morenosd1
1600 to 1835????
ok guys I need help. I want to re-built my engine from 1600 to 1835 I know I need to get bigger cylinders. my question its what can I re-used from the rest of my part I mean what did I kneed to know to make a good engine to run good. thanks.
turboedbug
Re: 1600 to 1835????
Depends on the condition of what u have, do u have everything apart now? If u do u could post up.some pics and show the condition.
Turbo!
helowrench
Also depends upon your goal.
What kind of vehicle and its intended usage?
Also what 1600 are you starting with: single port of dual port. Also, not all cases are not the same, some are better and some might be risky from what I understand. Look for the one or two letter code that is on the case under the generator/alternator stand mounting area.
helowrench's post is very important: you have to know where you are going before you can get there safely.
