oil cooler
mlrailguy
oil cooler
Was wondering about oil flow, from adapter to cooler. Which port is out and which is in?
- sideshow
Re: oil cooler
The trend in coolers are non-directional
Re: oil cooler
While it probably makes no difference to the cooler, it still might be helpful to know - for example, if one is installing a temp gauge sending unit.
On the top of the case, the port closest to the oil pump/oil pressure switch is "out"; that translates to the top port of the common external-cooler adapter which faces the flywheel end of the engine.
