I have a zero offset kit.
do they offer longer studs for the hub? I may have to run a spacer to clear the wheel
It says in the instructions that one may use 19mm bore for just the front disc setup
is the 20.64 bore master cylinder a super beetle 71-79?
Has anyone used these with centerlines. straight or bubble?
CSP Brake questions
Re: CSP Brake questions
Super master has an angled/clocked bolt pattern and won't bolt into a regular beetle.
What rear brakes are you using? Most likely you will be fine with the standard dual 19mm.
s
s
Steve
My Baja Build
My Baja Build
axam
Drum on the rear. I just want the best package I can put together.
Daily driver.
Daily driver.
I have CB front and rear with the standard 19mm later MC. It works spectacularly. 2 psi residual pressure valve on the rear circuit but perhaps no necessary. High and hard pedal, and great balance.
What front calipers are used with the CSP kit?
Steve
My Baja Build
My Baja Build
