I'm thinking from the end result backwards in terms of what would be BEST for choice of Megasquirt hardware/software. I'm going to talk in lame mans terms too, so anyone else starting out can use this as a reference or learning thread.
I hate carbs...and distributors. I'm over it.
The end result I'm going to have is my current 1776 will be turbo'd, with a sequential fire spark and fuel. I will eventually work up to this, but would like to buy whatever system I need to run this now, so I don't have to go through the trouble of changing out anything when the time comes. What MS system and software will give me this?
The first thing I would like to do is get the distributor off my car. I want to utilize crank fire. I don't want the ford EDIS system, because many make it sound out dated and maybe difficult to find. I want to use the MS controls for ignition.
After I get electronic ignition under control, I want a mexican FI system and remove my dual 34ICTs.
Then, turbo.
I also have questions about VR (what is that anyway?) Hall sensors, and utilizing crank fire. Does the sensor run to the MS box?
Also, the one thing that has been getting me confused, is the different fuel and spark options. Specifically, how can you run a gang injector system and also run a wasted spark system? Doesn't the wasted spark end up burning the gang fired fuel? I just cant picture this in my head after all the reading
EDIT:
Ok, did some more reading of actual MS hardware guide.
http://www.msextra.com/doc/pdf/MS2V30_H ... de-3.3.pdf
It looks like the MS2V3 will be able to do everything that i EVENTUALLY want. They have a nice write up about the EDIS system, and really make it sound doable. The EDIS system is something that can be ran initially, and then changed with out changing the main components of MS to utilize sequential COP ignition later, correct?
Does anyone utilize a MAF? I know my '76 2.0L Westy has one, but I never see or hear any mention of one in the builds on this forum.
