84c x 103 ( 2800cc )
5.7 h-beam rods/ new 3/8 arp2000 bolts
moly coated main,rod & cam bearings
new pauter dual pattern cam ( 1" base circle ) .560 lift, 320 dur./274@ .050
1.48 pauter bushed roller tip rockers
dual taper cromoly pushrods
old school aria's forged pistons (samba classifieds) , ceramic coated tops & moly coated skirts
48x38 heads with 11 to 1 cr. & ceramic coated chambers & valve faces/plus exaust ports
CB's vw650 springs with BP's titanium retainers & modified comp-cams lash caps (geometry correction)
twin spark plug conversion ( EuropeanMotorWorks
ceramic coated exaustports & stubb pipes
line bored & shuffle pinned (EMW
1/2" thru bolts
1 7/8 cfr tangerine exaust / recoated black ceramic
CB's 48mm dual throttle bodies & efi system (eventually megasquirt2xtra efi )
custom dry-sump oil system
11 lbs. flywheel, KEP stage II p.p. & custom clutchnet disc
cheers Bill D.
