Speedo cable hole?
Chip Birks
Speedo cable hole?
Post by Chip Birks »
Anybody have a spindle laying around that can measure the diameter of the hole through the spindle for tge cable to feed through? Anybody know of any passenger side spindles that are drilled through?
Re: Speedo cable hole?
Post by Marc »
The RHD cars still drive the speedo from the LH dustcap/spindle. I'm out of town right now so I don't have a spindle handy to measure the bore....
Chip Birks
Figured as much, thanks for the confirmation on the RHD.
andy198712
Post by andy198712 »
just checked my rhd (any diff?) disk spindles and i can put an 8mm head stud down it (tiny bit of wiggle to it) but its not a straight hole, its got a bend near the back (i.e. nearest backing plate)
hope that helps?
andy
helowrench
Post by helowrench »
.325" from spindle nut side. All the way through, no steps or shoulders.
.475" from ball joint side X.900" deep (pocket for the rubber bushing)
helowrench
andy198712 wrote:just checked my rhd (any diff?) disk spindles and i can put an 8mm head stud down it (tiny bit of wiggle to it) but its not a straight hole, its got a bend near the back (i.e. nearest backing plate)
hope that helps?
andy
Went back out and looked, you're right.
That .475" dial pocket is leaned away from the ballpoint 10-15 degrees.
Anyway. All measurements taken from a Ghia ball joint spindle.
If you need more particulars, holler back.
Chip Birks
That is great! Thanks guys!
andy198712
helowrench wrote:.325" from spindle nut side. All the way through, no steps or shoulders.
ah, i wondered what that counter bore was for :)
helowrench
Yep, hat shaped rubber bushing that holds the cable in place
Bruce2
Post by Bruce2 »
Chip Birks wrote: Anybody know of any passenger side spindles that are drilled through?
About 10 years ago CB accidentally drilled the right spindle on a set I had. Be tough to find that one now.
