1.7,1.8 & 2.0 case differences ?
got914?
What are some of the differences ?
Im new to this type 4 thing and im reading alot on this site but wanted some info here.
- Type 4 Unleashed
Re: 1.7,1.8 & 2.0 case differences ?
If your talking about motors out of the 914 there pretty much the same, except where some have the 2nd oil pressure relief blocked from the factory.
Motors in the Bus's & the 411 and the 412 are dimensionally the same, small differences on those are dip stick & oil fill locations, and the breather towers blocked off on some, and I believe all those have the 2nd oil pressure relief.
EMW
EMW
The late Vanagon cases (`80-?) had the blocked off breather "chimney".
(NA had fewer engine options than the rest of the world)
The early cases had the second pressure control valve on the 1/2 side of the case, near the lifter bores on #1.
The later cases were set up for hydraulic lifters, and had that area plugged (actually just not machined) from the factory.
This second pressure control//relief valve can be disabled with a short metal rod in place of the piston.
Interesting thing about this valve was the piston had an ~ 1mm hole in it as a full time bleed, I think of it as an air escape path should the pickup suck some air going around a corner, rather than having to work it out via the bearings.
the 411/412 cases were all "early" style, not sure about 914 75/76 cases, they were also solid lifter.
Busses of the era were getting hydraulic lifters, at least in NA.
Jake Raby used to say the earliest cases (EA etc) had somewhat thicker castings in some areas, and the 1700/1800 and non-bus cases were most likely to be in good shape due to lower heat/loads.
Folks have used solid or hydaulic lifters in all the cases.
Hydros are discouraged due to their still requiring valve adjustments, alarming noise on startup when they leak down sitting and pick up some air, and their way of "hiding" valvetrain issues (by taking up valvetrain slack as designed) until it is too late.
Ktk833
I'm glad this was asked and answered.
Being new to the type 4 as well, I grabbed a block that might have been manipulated a little... it has no dip-stick (I wonder how the guy checked on levels).
What are the likely spots I could find the slot of the stick? The tinware seems to have covered the first place I'd have expected to find it- at the base, next to the oil filler connection.... (or in silly question- is there a block without a dip stick??)
The 411 and 412 sedans as well as the 914's...had the short dipstick up top near the oil breather tower. The type 4 based bus engines and the 411 and 412 wagons....had a remote dipstick.Ktk833 wrote: ↑Thu Aug 23, 2018 12:04 am I'm glad this was asked and answered.
If you have a case with no dipstick up on top.....look for this....when you are looking at the fan end of the engine case...look at the lower right hand corner down near the bottom of the case and you will see about a 1" diameter hole with a mounting flange and two studs or bolt holes. This is where the dipstick mounted on those. It had a pair of rubber boots, a telescoping dipstick (at least on the 411 and 412) and it went through the sheet metal to a dipstick cap right under the rear hatch so that you did not have to lift the engine lid up to check the oil.
If you have a 914 or 411/412...you can buy a used short dipstick and tube and drill out the hole in the top of the case and install it.
Also....the later bus cases that came from teh factory as hydraulic....that got rid of the oil control valve under cylinder #1....also had a difference in the casting of the relief valve area that delivered the diverted oil back to the oil pickup area. Ray
bajaman73
Sorry for the jump in. Will 2.0L Pistons and cylinders fit in a 1700 case with no machining?
1968 Ghia - Street Cruiser - 1600SP
1971 Ghia - Street/Strip - 1915 Dual IDF
1959 Ghia - Drag Only - 1915 Turbo
Yes.the cylinder bases are same size for all.
1700 heads need opened up, 100mm register vs 105mm for 1.8/2.0.
bajaman73
Thanks PileDriver. I have a 2L Currently with a bad crank for sure and who knows what else.. Getting a short block in pieces (all Machined or new) and going to use my top end. Hopefully..
Ever heard of a CA case? Supposedly a Replacement from Canada?
Slow 1200
CA is a bus 1700, euro spec
Ktk833
Thanks ray for your response on the dip stick matter. Much appreciated.
Eddie010
I found out that some oil pick up tubes are different in lenght, the oil pick up tube from a 1700 and 1800 engine are longer
on pump side then the ones from a 2000 bus engine.
The hydraulic cases take the shorter pickups... the oil pressure bypass oil goes through a passage and back into the pickup tube just past where it plugs in.
There has been some discussion whether this is a bug or a feature... I do know it might be a feature at higher rpm, but you'd be better off eliminating where the pickup pinches down for the sealing oring as well.. the id is way too small where it pinches down for high rpm.
Note that if you go dry sump, you want to route that bypass flow to the external tank rather than the sump, just so you dont keep having to pump it back out.
